everytime i start my car up in the morning and wait for it to warm up it starts leaking coolant. its been going on for about a month. is this normal or can it become a big problem? it only does it in the morning when its cold.
coolant leak in the morning
leaks coolant from where? how do you know its leaking coolant?
Yeah you need to track it to the source, if it leaks enough.
I've been loosing a few ounces of coolant a month this winter, but not enough to see where its coming from. Also know a 300zx that will loose a couple ounces overnight when it gets well below freezing, once the engine or outside temp goes up a bit, it stops. I know the 300 has old hoses that are likely the problem, but not sure what's up with the CB. Both just get a little pre-mixed coolant added to the resivour every few weeks.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
check the hose underneath the distributor, that was the hose I just had to replace, the one that runs from under there to the heater core/T-stat. Its a fitted hose so if you have to replace it only Honda carries it...like 10bucks
