I just put these wheels and tires on and I am getting a rub on my driver side rear on the inside when I go around a corner. What could it be rubbing on and why?
Tire rub on 1 wheel
sagged springs maybe? or a blown strut. I have those on my car as well and I'm lowered 2 inches and I don't get any rubbing.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
yeah i rub too in the back when i take a corner hard. but just in the rear, I think you could roll your fenders and that should give it the clearance it needs. That's what i need to do but i just need to find a good way that's cheap and effective haha.
Originally posted by Losiracer2yeah i rub too in the back when i take a corner hard. but just in the rear, I think you could roll your fenders and that should give it the clearance it needs. That's what i need to do but i just need to find a good way that's cheap and effective haha.
is the tire rubbing, or the wheel kinda grinding?
the inner edge of the wheel is probably rubbing on the front knuckle... its a wider wheel so it sits a little deeper into the wheel well, and hits on full turn. it happened to me when i had those wheels, as well as others.
you might need spacers like wed3k said. or just dont turn that far :P
if you take the wheel off and look close, you can see what part of the wheel is rubbed clean...
and as for the rear not sitting level, it could be the way you were parked, or could be a bad shock on one side? which might also explain your "movement" you mentioned.
