I had my car in for service for an oil change and the tech told me that I needed a new valve cover gasket because I have oil on my spark plugs. No big deal I have done it before. He said he would charge me $60 for the service and he which includes a valve job. I can do the valve cover gasket myself do I really need a valve job what does that do? My car runs fine as it is.
Do I need a valve job?
Originally posted by TypeGdo you mean valve adjustment? if your valvetrain is noisy then you need one.
and oil in the spark plugs are cause by deteriorated spark plug tube seals. later.
it sounds like a bunch of light ticking...kind of hard to describe on a computer.
yes there are o rings inbetween the head and valvetrain. there are also round gaskets on the valve cover where the spark plugs go, but those never leak.
here is a thread that can clear up any questions you have:
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals
later.
its not too complicated but it requires a lot of patience and an achy back, especially the intake valves
remove and install the valve train in the proper order
I've replaced the bottom o-rings on both my cb's to fix the oil in the spark plug tube problemLast edited by accordaffair; 10-11-2007, 10:04 PM. Reason: intake valves are in the back, not exhaust! not a k-series
Valve Adjustment never hurts..
I paid $180 from honda which is a good price.
SP Tube seals
VC gasket
Valve adjustment
new spark plugs
Free OEM USDM Gigantic Muffins
Free OEM USDM Coffee
Local shops charges me $145 for valve work only.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Ok looking at this im going to let my buddy (which is a Honda Tech) Do it for $60 I thought it was easy as just doing the O rings but im not going to go much further than that. I guess a valve adjustment can't hurt for $60 its well worth it. Thanks for all the info thats why I always consult with you guys before doing work or getting work done.
Lol, valve train i thought is the controlling valve unit in the transmission... intake and exhaust valves are just refered to as valves. Getting the gasket installed with a tune for the valves for 60 bucks is a good deal.
Free OEM USDM Coffee90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by DreCB7Ok looking at this im going to let my buddy (which is a Honda Tech) Do it for $60 I thought it was easy as just doing the O rings but im not going to go much further than that. I guess a valve adjustment can't hurt for $60 its well worth it. Thanks for all the info thats why I always consult with you guys before doing work or getting work done.
Originally posted by js593To do that, dont you need to compress each cylinder to keep the valves up? or does taking off the rocker drop the valves into the chambers?
adjusting the valve lash is adjusting the gap between the tip of the rocker arm and the tip of the valve... which gets altered slightly after removal and reinstallation.
yeah, you turn the crankshaft by hand, theres a hole behind the drivers side wheel you insert the extension/socket wrench, etc
http://media.honda.co.uk/car/owner/m...l/400/5-14.pdf
