ac+header=no go?
    ac+header=no go?
    ok well i bought i header and spent all day takin the damn heat shield off and rusted bolts off.
    once i got every thing off i went to put it on and my ac lines r in the way. i now have to get it decharged and take it off
    UNLESS i can get another fitting for the ac. do they make them?
    can you bend it? what exactly is in the way? what header is it. should work
      x2 you should be able to bend it. One of the AC hoses sits really close to the header off the compressor you should be able to pass that a bit.
        Wow... I've never heard that one.... I don't think you should have to "decharge" anything bro.... You may just want to go to a local shop man... Do think you should have to decharge anything for a header.
        My Members Ride Thread ( Do It )
          ya it should work, how far out do the headers go? many, and i mean many people have put headers on their car and kept A/C. Just look through the members ride section.
          Where exactly is it interfering?
          ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
          NE GUYS, Buy the last of my accord parts
            I know my car header sits close to the high pressure line that comes out of the ac compressor. Anyway if your doing it on a stock motor it should bolt on. Either way my header was put on with the AC still in tact with the h22a also. You just need to wiggle it in or get the right angle. You can unbolt the AC if you want its just 4 bolts and a belt then just bolt it back on when your done and you wont have to decharge anything.
              the fittings stop it from bolting up the header to the bolts. ive already spilled coolant on me be4 and it sucked. not tryin to do it again so i had it decharged and it probly needed it n e ways so its cool
              ill get a pic of it soon. they need to be bent so the header can be moved over an inch toward the driver side.
              the exhaust is just an ebay one
                ok here is a pic of the fittings. the big bright orange thing is my stock header
                  just bend it. someone else already has and that's the problem
                    which header did you buy?
                    the ebay header on my H22 barely hits and i had to lightly bend the line out of hte way...
                    i bought a cheap ebay header for my F22 and it lands right where the fitting is, bending it wont even help. :grr:
                      just a bad design or something? sure they sent an f22 header or is it the flange that hits and is oversized or something?
                      i always thought they just copied the DC design with cheaper welds/materials
                        bad design, as it also tapped on the crossmember. it was a cheap-cheap ebay one though, one that probably didnt make its way through QC...
                        the one on this h22 though was a little better quality and touched the line, but only during installation. once on, it didnt hit.
                        this f22 one directly interferes.
                        not sure what header the OP actually ended up with, as theres a whole slew of "brands" on ebay
                          ok basicly i just bent the 2 AC fittings. it took a hella long time to get them bent to the right angle but its worth it! i got the header on and i also have AC!(just gotta get it recharged ) it was a cheap ebay header(works great BTW!)
                          well i think im gonna make a DIY for this cuz it sucks major balls to have a header but u cant install it. its really not hard its just time consuming cuz u gotta like alter some stuff to make them fit.
                          i also had to alter the thing that bolts up right be4 the flex pipe. im sorry i cant think of the word at the moment.
                            what header is it?
                              Originally posted by h22boost
                              what header is it?
                              its a random ebay header but if u wanna kno the company here is the link
                              http://cgi.ebay.com/ebaymotors/ws/eB...155007934&rd=1
                              and here is a pic on my car. its startin to darken
