jumpy car
    jumpy car
    Ok,
    so, when i am going around even a slight corner and hit a bump, the car goes squirrely. Like, it jumps to the side a tad.
    any ideas?
    My Car
    FREE Web hosting solutions
    first
    explain wats really happening and i suggest you check your tires first for pressure, then lug nuts, or loose axle nuts, then any suspension parts that might be loose, or broken rubber parts, if not any of these then check the tie rods or ball joints for wear and tear. good luck searchin.
    OLD
      what kind of tires
        Well, I've got contiprocontact 205/60/r16's. The car was just inspected in may. I got the tires/rims in the end of april.
        it feels like i slide out a TOUCH just a little when i go over a bump while in a turn. usually a hump like where the asphalt bumps in a line across the road. Like, i go over and it... just feels unstable. Like it sways back and forth or something. I was thinking lowering it would solve the problem. maybe center of grav is to high? Maybe shocks are bad?
        My Car
          As noted check suspension components. Upper or lower balljoints can give these symptoms.
          I had similar issues where the steering wheel felt like it was getting away from me over bumps. I had the upper and lower replaced (not at the same time) and its no longer an issue.
          '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
          EX Lip & Alpine OEM single CD Player. No more useless pocket!
            Another thing to check is the sway bar end links. My Mom's EX had the same problem you're talking about and a lower ball joint and sway bar endlink fixed that problem.
              yeah, seems like its only a problem when turning to the right. could the shocks be going bad?
              My Car
                It could definitely be shocks.
