H22 Hesitation between 2-3k
    I just installed my H22. Everything seemed to be working fine then all of a sudden the car starts to hesitate at around 2.5 k until 3k then takes offs.
    I slowed down to get back into that RPM range and it did it again and it does every time I'm around that RPM range it hesitates a little. One time it did it so bad, I ended up turning off the car while rolling and started it back up and the problem disappeared. No CEL.
    Every since I installed the engine I never really noticed the low end torque I thought this H22 would have. It feels really weak when taking off. Could this hesitation be a timing issue? I have seen a lot of post about Knock Sensor might be causing this but no definitive answers have been posted. Anyone?
    Is the EGR system hooked up and clean?
      What kind of exhaust are you running?
      Originally posted by lordoja
        check engine light on ever?
          Yes the EGR is connected. I cleaned out the egr and even installed a new one. Still the same problem.
            APEXi WS
            I just installed a Apexi-WS catback. Much better when VTEC kicks in. Before it felt like the air just wasn't coming out fast enough. Still the same problem hesitates around 2-3k RPM
              No CHECK ENGINE light. I have seen a lot of post about this but no clear answer. Some say timing, some say Knock Sensor, Some same Distributor.
              I have never had the Timing Checked. I installed it with the way the engine came. One thing that’s confusing is that when I restart the car, the hesitation disappears. Like the ECU resets something. Could it really be the Knock Sensor? Or could my timing be off?
                Buying a new exhaust won't help with the problem. Did you check your cap/rotor? spark plugs/wires?
                SOLD!!
                Boosted H22
                375whp 298 ft/lbs at 15psi
                  The stock exhaust had a hole in it that is the reason I purchased the new exhaust as well as for the look. I have check all the tune up parts and everything checked out.
                  I did notice that after I changed out the plugs the power was beautiful then, that's when I really started to notice this hesitation the next day.
                    Grounds...
                    I am going to check my grounds. I called the Engine company where i purchased my H22 from and they told me that this issue sounds like a ground problem. I am going to buy some ground straps from autozone and redo some grounds. I will let you know how it goes.
                      may as well redo all the grounds
                      Originally posted by jboyce
                      i f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
                        You should definitely check your timing.
                        Did you take off or move the distributor at all? Some people only replace cap/rotor and think its fine. A lot of times, the timing is way off.
                        Just yesterday, I checked the timing on an h22. It was SUPER retarded, even tho the distributor was in the middle. The guy's had his h22 for at least 2 years and never checked the timing. He never had any hesitations, but still.
                        Also, did you do a timing belt job? Did you mess with any wiring?
                          I installed the engine with the original timing belt is looked like new. So I decided not to mess with it. I never touched the Distributor. I remember when I first connected the ground from the batt to the upper frame, the cable got really hot to the touch while the engine was running.
                          I added another ground cable to the transmission and connected to the batt. I drove the car and it felt smoother, in just about every gear. I thought it was in my head, so I removed the cable and drove it again and there was noticeable difference smoothness was gone. So I connected that new ground and the smoothness came back. It feels really smooth.
                          I don't feel that hesitation anymore. Maybe it was the ground. I will keep my speed in that range as often as possible to see if it comes back; So far so good.
                          I will also get a timing gun to check the timing. What should the timing be set too?
                            15*BTDC.
                            Just get a regular timing gun and align the marks on the flywheel to the marker on the engine.
                              Great will do. One other thing. I noticed that when I turn on my A/C, the idle drops pretty low and then comes back up and drops again. I have heard that having to much Freon in the system can cause this. Is this true, could it be something else causing this?
                              I really appreciate your support with this.
