V3 sparkplugs ????
    V3 sparkplugs ????
    Hey guys
    there are these spark plugs, i dont recall their name, its like V3 or something, they have 3 igniting tips at the instead of 1, and they supposedly ignite much better
    anyone try them in their cars ?
    Members Ride - 1993 Honda Accord EX
    not me, stick with ngk or denso. Honda's don't like any others.
      why do you say that
      what is the comparative to NGK iridium ? for ND ?
        Hey guys
        sorry, it is E3 spark plugs
        e3 spark plug
          I just switched my bosch platinums with the stock ngk v-powers and noticed no difference.
          The NGK's are ten bucks for 4, the bosch were 33 for 4.
          I'll put in a vote for the basic standard NGK's.
          PM me for the following...
          -Driver's side 2-door armrest in tan for sale - $5 + shipping
          I'm currently looking to buy an N/A mkIII (86.5-92) supra. PM if you or anyone you know is selling anywhere near CO.
            there was a thread about the sparkplugs a while back and everyone seemes to like NGK better than anyother sparkplugs
              in a honda, stick with OEM such as DENSO or NGK. reason being is that even though bosch or any other american made spark plug will give you mroe power in the first 1000 miles or so after that they are pretty useless (such as lagg and not as responsive) oem in the other hand was made specifically for our vehicals hence it will last the 10-15k intervals. Mine are 30k spark plugs but there 15 bucks each.... but if you trust foreign objects in your car go for it if not go with oem
              either kill it or drift it...
              2002 Toyota Tundra V8
                OEM uses NGK why shouldnt you? Who knows better than OEM? Anyway spark plug/wire aint gonna be making much of a difference until you start pushing big power. And stock honda ignitions are pretty good from factorry as is.
                  so these e3 spark plugs wouldnt work straight with honda engines i assume ?
                    ive heard people complaining that the Platinum +4 (4 tips) bog out their cars and dont ignite well enough.
                    i dont really see a need for multiple points... a good solid spark from a single tip sounds good to me, and copper NGKs work great and are cheap and disposable enough to swap out whenever you feel the need.
                      I work at a parts store and some of the people that come in hear all the hype of the Bosch Platinum +2s and +4s and come in and pick up a set. I've had SEVERAL customers come back complaining about how these spark plugs make their engines miss. The spark plugs with the "multiple firing electrodes" are ALL HYPE. THEY ARE JUNK. DO NOT WASTE YOUR MONEY ON THEM.
                        Spark plugs alone will not give your car more power. Also, spark plugs should last around 60k. If you're changing them every 10-15k you're throwing money away.
                          Spark plugs allows us to MAKE MORE POWER so therefore they will allow your engine to produce more HP. if you did not get the statement I made earlier.
                          your dumb if you think regular spark plugs last for 60k unless there were iridrium... and they usually cost about 17 bucks a piece denso brand.
                          15k is usual interval for spark plugs from HONDA. - V-power
                          mine are 30k plugs since there double platinum from HONDA
                            What do you mean spark plugs allow you to make more power? Have you ever heard of a turbocharged car just adding spark plugs to make more power? I sure havent. I have though, heard of a FI car adding an ignition box (ie MSD, Accel, etc) for more spark power. And just FYI platinum plugs should be good up until around 100k.
                              whatever dude do whatever you like sigh thread should be closed now...
