Going to Replace Water Pump question...
    My water pump is leaking, and I'm going to replace it, timing belt, and balance shaft belt.
    If my timing belt hasn't broken is it a requirement to move the motor to TDC before removing the belt. My thought if I remove the existing belt without moving anything and install the new without moving anything wouldn't that still be ok?
    You need to set everything to the marks. It dosent matter if the belt broke or not. If the belt broke you would be changing more than the belt and water pump.
      Also it is 10x easier to line up everything before than doing it later. You do it first it saves you time.
        do not take the belt off without lining up every mark first. then put the belt back on, double check that each mark on every gear is lined up, then tighten it all down. its the only way... attempting to do it "as is" will lead to things been off a tooth or two...
