Exhaust
    Exhaust
    Hi.
    Does anybody know if the 5gen (94 - 97) Accord exhaust fit the 4gen??
    Or does some other Honda modell fit?
    Thinking of bying Tanabe Exhaust, but they don't have to 4gen Accord.
    Thank you.
    there is a company called Tsudo that makes 2.50" exhaust for our cb7s that have an apexi n1 style or a 5zigen fireball style tip. i found mine on ebay for $310 shipped.
    OHIO CB7's
    My Ride
    MOD FUND: better if I could sell some of my stuff.
    Build Thread
    vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
      Thank you, but have got a good deal on Tanabe Exhaust. So i just need to know if there are any other Honda model that fit the 4gen Accord.
        Found this on Ebay, it might be what you are looking for.
        http://cgi.ebay.com/ebaymotors/90-93...spagenameZWDVW
        My 1991 Accord DX
          I hav seen this. But that is not what i want. I want to know if Accord 94 - 97 Exhaust fit the 90 - 93 Accord.
          Or if there are any other Honda models that fit.
          Thank you.
            Have anybody tryed to fit an exhaust from another Honda model.?
              from experience it would fit. just need to do some slight modification. all i did was to weld my new exhaust to my existing stock pipings.
                Thank you.
                  It will not be a direct fit. Some modification would be necessary to make it fit, and the stock hanger positions probably won't work. If the deal you are getting is REALLY good, and you can weld (or know someone that can), then go for it. If not, you're better off finding an exhaust made for the 4th generation. I know at least one member on here with a Tanabe system, so if they don't make them now, they did at one point... which means you should be able to find one, if that's what you really want!
                  zero2sixtyr35, you said that you welded it to your stock piping... so I assume that means you didn't use a full cat-back system. When attempting to install a 5th gen exhaust from the cat back (or header back, if they don't use catalytic converters in Norway) it will not bolt up correctly. If simply weld a muffler and some of the piping onto the stock piping, of course it will fit. At that point, it's nothing more than a muffler.
                    i welded a new axle-back system into my stock piping. had new hangers welded also.
                      Originally posted by hondacc90
                      Hi.
                      Thank you.
                      y would u want a 5th gen exhuast on a cb7
                        as i understand it, the 94-97 exhaust will line up on a CB7 fine, from the rear canister all the way up until the cat convertor. at that point the piping is too long... youd have to get some cut off and welded, but it should line up otherwise
                          Because he is getting a good deal on it. Plus he said tanabe is not available on 4th gen.
                          Click for my ride thread.
                            Go with the tanabe medallion style exhaust. Looks stock yet it has a great sound to it. Thats next on my agenda...
                            CB7Tuner Resident Gamer!
                            PSN: JDMcb7TX
                              Any alteration to the system may change the sound, though. It may not, but be aware of that before you do anything.
