Is it okay to get used struts from scrap yard to put in car ?
    If the struts are fully inspected, is it okay to use used ones ?
    How much time should this take for a mechanic to put them in ?
    Would i be running into any other cost ? like if the one spring is rusted looking and won't go back in ?
    if youre tight on cash, just go to autozone and get their basic ones, they are like $44 each... putting junkyard struts on your car is just begging to have to bring it back to the shop to get it redone....
      If you can get them really cheap, and are willing to do them yourself, then perhaps it's worth it... but if you're paying a mechanic to install them for you, don't get used. It'll just end up costing you more in the end! You never know how long they'll last!
      Also, springs rarely go bad. You'll want to inspect your ball joints and various bushings, however. They DO go bad, and can cause issues... from bad camber and alignment, to total suspension failure! Any broken or cracked rubber should be replaced with new OEM Honda parts (or Energy Suspension urethane, in the case of the bushings, if you want an upgrade!)
