My battery light is going off and on, whats happening
    its really weird...when i press the accelerator and give the car gas, the battery light flashes red. when i let off the pedel it will stop
    after about 15 minutes of driving, the light starting coming on only when i brake. what the hell is going on!!
    bad diodes in the alternator... you're going to need a new one soon either get a Bosch, Beck Arnley, or Denso
    Bosch part #AL1260X
    Beck Arnley part #186-0542
    Denso part # i dont know
    I need NOS... give me one of these... make it 2... oh and hairy... i need it by tonight!
      1. Alternator is going out as mentioned.
      2. Pull off the part and bring it to autozone or some sort of part store to test it.
        Check Your Battery Fuse Or Wire
          without a doubt the alternator, just happened to me the other day.
            alternator(as mentioned) and/or battery terminals. may have acid build up or corroded.
            94 Accord Wagon EX-R/H22A 5 speed
            91 Accord Wagon EX-R/ F22A6 5 speed
            93 Accord Wagon EX/ F22A4
            91 Accord Sedan EX/ F22A4 5 speed
            94 Accord Sedan EX-R/ F22b1 5 speed
              if ur battery is good then its the alternator diodes and if u battery is bad then it might be the brushes in ur alternator
                .../\ i love it when people agree with me ... maybe because im right... who knows???
                  god dammmmiit. how much does an alternator cost, is it easy to install? the battery looks pretty new to me.
                    i think there like 50 bucks on ebay find one on here they arent that much
                    93 accord: F22A swap,T3/T4 turbo, tail wastegate, front mount 27x13x3, hks turbo timer, turbo xs boost controller, msd igintion, 3in downpipe, crane cam 11mm plug wires, denso plugs, no ac or ps,wire tuck, cutted insides, one seat, auto meter boost gauge,oil pressure, a/f,and 5 in tach,act clutch and flywheel.
                    93 prelude: jdm headlights,OEM carbon fiber hood, tein lowering springs, work racing rims with kumho tires, msd wires and denso plugs,type r shift boot
                      i just bought one and is like 130.00 in outozone!
                      but yea it's the alternator!need to replace.
                        LOL
                          Alternators aren't hard to install, but new ones aren't cheap. Used ones can be had for fairly little, but then again, you can't be sure they'll be any better!
                          To install, it's just a couple bolts, a belt, and an adjustment screw. Just make sure the belt is properly tensioned... it'll squeal if it's too tight or too loose.
