ok heres the deal my cb9 i noticed when i left the kickdown cable unhooked from the tb the gas pedal felt smooth and soft when i put it back it was hard again could this cause 3000-3500 rpm gear engagement that im having???,,,,,also can the egr cause the car to run rough when its bad even though its blocked off,,one more thing sorry i think my igniter is going bad cause she surges at idle like my old nissan did before i had to replace the distributor i got spark all new vac lines spark wires fuel filter any info would be a great help thanks alot for your time guyz
Cant Figure These Out!!!!!!!
Originally posted by Akira_kjwow, huh?
One problem at a time. Maybe you should put this one in the advanced section of the fourm.
Your probly on a AT so, no, your tcu should be dealing with shift points. The rest I have no idea.
1. Do you have the sports button depressed? Been a while since I drove an auto so what did it "normally" shift at?
2. Surging is caused by vacuum lines or your IACV/FITV depending on when it occurs.
3. Blocking off the EGR will increase emissions which is not good. Don't really think it will let the car run off just your mixture wont burn as complete when idling/cruising.
replace the kickdown cable, it will not work right without it, and by the sounds of it, its sticking.
