Is there a write up on putting a shift light on a stock tac. on here? If there is I couldn't find it. this is something Im sure someone has done before and I need to know where to tap into and all.
stock tac. shift light
You mean like in the cluster? It is doable but might need to drill into the cluster. Other people just buy a chipped ECU and use the CEL as a shift light.
you could always take something like this http://cgi.ebay.com/ebaymotors/6-99-...96540074QQrdZ1, open it up and mount the control knob somewhere, and use your own cluster mounted mini light instead, wired in place of the super bright one it comes with
Originally posted by bigrob-CB7Is there a write up on putting a shift light on a stock tac. on here? If there is I couldn't find it. this is something Im sure someone has done before and I need to know where to tap into and all.1993 Accord EX
1993 Civic HB
1994 Integra 4dr
2006 BMW 330i
2006 Suzuki GSXR
there are 3 wires if i remember...ground, power, and tach signal from your distributor....Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
i di my auto like that with a autometer light i hooked the red to a power sorce that comes on when u turn the key the black wire to a ground cut the orange and brown wires and if you take the trim peac off the gauge clust look to the left under the tach at the blue wire that is where i hooked the tach sinal wire to
Originally posted by ilovemycb7Why do people want shift lights... ? For shifting right at redline?Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
CEL = Check Engine Light.
