help!!!! hot engine won't start
    wats up guys my car was running fine till i start it up again and it won't start battery fine, don't know if its the relays.. thanks
    does it crank over?
    Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
    -(B-Pillar Bar Originator)-
      yes it cranks
        also wit full tank of gas
          so it wont start when its hot?
            check for spark and fuel
            PSN ID's:Tidashoni
            1992 Accord EX Coupe
            My FS Thread
            Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
              Fuel Filter
              Street Racing is Lyfe
              Crip is How We Roll
                main relay sounds like it...
                check for fuel and spark first to make sure its not an ignitor or anything
                  when its hot, meaning the car is hot inside, or the engine is hot?
                  check to see if youre getting spark, pull one of the spark plug wires out and hold the tip near one of the chrome nuts for the valve cover, and have somebody try to start it. if u dont see a spark jump from the wire to the stud, you have an ignition problem... and i would assume its the Ignitor in the distributor.
                  if you have spark, you may not be getting fuel... which may be the main relay, but thats usually only a problem on really hot days, when the car has been sitting.
