anyone know of someone putting in the 3.0 v6 in our cars
3.0 v6
Yea a shit load of people if you search. They are all talk but they dont back it up. And its pointless as already mentioned. It would be cool but not worth it in the end IMO.
its only a matter of time before somebody tries it.
I would agree that it isn't easy, and there are easier swaps out there.
However.
What do you have to do to an H22 or F22 to get it to 265+ WHP?
Yup. You are going to have to build or boost it.
A J30A4 or A5 will do it with a few good boltons.
At 4lbs of supercharger boost, they lay down around 300WHP.
Originally posted by ilovemycb7It would just be awesome because no one has done it. Like the guy with the f22 in his civic. Just cool. But lots more expensive...
Honda has several 3.0 liter V6's.
They are cheaper than an H22.
It amazes me that everyone says that an H22 is a worthwhile swap because it goes right in, and they have no problem paying $2500+ for a complete swap.
I can get a J30 for $600 or so, and the transmission for about that.
That puts me at $1200 for something that has AT LEAST 200HP and 195lb/ft of torque, both at much lower RPM's than the H22 produces.
Since the only manual transmission available for that engine is the 6 speed, I also have a gearing advantage.
With bolt ons, the LEAST powerful J30 will put down 200WHP and almost as much torque, while a J30 from the current gen Accord usually puts down about 215-220WHP STOCK.
With bolt ons, I can get it to 250WHP. By bolt ons, I mean intake, exhaust, downpipes, TB spacer, crank pulley, and Hondata style IM gaskets.
Not a lot of stuff, and not very expensive either.
The V6 doesn't have a lot of aftermarket support, but considering that most built H22 don't make 250WHP, I don't think it really needs it.
Oh yeah, and unless its boosted, the H22 will NEVER make as much torque.
Also, the J series V6's LOVE the boost.
You dont think the overall cost of a j series drivetrain, axles, modifications to the cb7 chassis(mounts), on board dianostics II, Ecu, Exhaust, etc would surpass the h22?
Hmmm... I thought it would............................ interesting......
I think its a good idea though. Be one fast honda that actually has torque. LOL...
Originally posted by oozingmachismo2You dont think the overall cost of a j series drivetrain, axles, modifications to the cb7 chassis(mounts), on board dianostics II, Ecu, Exhaust, etc would surpass the h22?
You can usually find a deal on the 6 speeds if you look hard enough, but even if you can't, you can get an LSD 6 speed from a TL for about $900.
That isn't much more than what M2B4s go for, and they typically have about 25-50K on them.
So even at those prices, we may be at about $1500, which still gives you $700 or more to play with.
You usually end up replacing a bunch of stuff with the H22 swap anyway, and you may not need to in this case, but you would have some $$ to play with if you did.
The biggest issues would be mounts, axles and ECU.
Most of the hoses like A/C and powersteering etc, you could make with braided stainless hose and fitting which actually isn't that expensive.
It may also prove to be a better option to modify the wiring harness to make an OBD-I ECU run the car.
I would bet that the NSX ECU has the same connectors as rest of the OBD-I Honda ECU's, so perhaps something like AEM's EMS would work.
If you used a newer J series, you would have to replace the Throttle body with a cable actuated one because the newer ones are drive by wire, but that isn't hard to find either.
Ultimately, it would probably be more, at least the 1st time out because of the learning curve, but to get it to 250WHP, you would need the swap, and a few bolt ons.
With the H22, you are going to have to pretty much fully build it.
250WHP to 250WHP, you might be able to get pretty close.
