Why don't I have an EGRValve gasket...
    I was going through pictures to check out the air boot valve and to see which vacuum lines I should check for my (eratic) idle problem. I noticed the EGRV gasket (circled in red above) which was definitely NOT there when I took my EGRV off to clean it and check it. I'm picking one up today. I went through my maintenance records and don't see when it would have been removed?
    oh well. its like $1 at autozone and I'll use a smidgen of rtvv gasket sealer as well.
    91 EX F22A4 - Stock w/ 220k mi
    My Ride - 12/06
    The only way is the previous owner must of replaced the egr valve and didn't replace the gasket or paid some hill billy to do it and they forgot.
    -1991 Honda Accord LX H22a-
      it usually sticks to one side. you sure both halves are bare metal? or was there any flakey metallic stuff on either side, which would indicate a gasket was used?
        not so much flaky...def soft is metal. So does this mean there "was" a gasket and it was removed and never replaced or there "was" as gasket and its disintegrated.
        My Ride - 12/06
          either or you need one, also how did u get the egr valve off, i cant get a wrench or a socket under the lip of the valve
            yeah, it was tough...but I used an socket extenstion w/ a wobble tip...
            heading to autozone now. ty guys/gals.
            My Ride - 12/06
              so I'm dumb...the "gasket" is a metallic/cardboard material...replaced it anyways...
              My Ride - 12/06
