I know someone here has done this before, they sent me a website to look for the urethane (www.mcmaster.com) I came up with the following part numbers: 8644K11 and 8644K18. which one should I use and how much should I buy? Will one pound be enough? Thanks.
Filled Motor mounts
Filled Motor mounts
"I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
ASE Master Automotive Technician
ASE Master Med/Heavy Truck Technician
US Navy Electrician
Contact me if you need help on the side.
'92 Accord DX (For Sale)
'01 Civic LX
'00 Tahoe
Greatest Rally Video EverTags: None
8644k24 = 60 hardness (1250 psi)
8644k11 = 80 hardness (1725 psi)
8644k18 = 94 hardness (3120 psi)
i prefer 94, but its uncomfortable. if you want stiff mounts but less vibration, get the 80. wouldnt recommend the 60. 1 pound is enough for 5 mounts.
most that i have seen go 80. unless my rear mount prematurely goes out or if i get to much wheel hop, i won't use either. i don't think i can handle the extra vibrations,lol. whats your set intent. daily, street, or drag.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
thanks for the info guys...the order is on the way...I'll keep you posted after the install."I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
US Navy Electrician
'01 Civic LX
'00 Tahoe
yeah the rear mount in the main one to even get done. when your car vibrates more that normal, check your mounts. both my front and rear mounts were completely gone. i couldn't understand why my motor vibrated like it did. when i dropped my subframe to do repairs i found out why then. the power of even a h22 auto is too much for auto mounts.91 Ex CB9
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
yeah...in the past 5 years that I have gone through 4 front mounts, 2 rear mounts and one of each side mounts...i am tired of changing them...i hope this does the job."I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
US Navy Electrician
'01 Civic LX
'00 Tahoe
how do u use this stuff? is it like a putty or paste you work in the mount? do u just take out the mount and pour it in there? Do u have to use a new mount or will the old ones work fine? sorry for the excessive questions but i have a front mount ripping and this seems like a good solution.
use a new or old one dont matter pret is the same wash with castrol super clean then spray with rubbing alchol wipe clean tape one side with heavy duty duck tape making sure to seal the edges good and mix the mcmasters crap as directed and add to mount with a spreader ie.... a pop sicle stick smooth surface when filled... pretty easy.... like a 20 min it job per mountfuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
R.I.P.
Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
