Okay i just got a new fuel filter and installed it, when i went turn the ignition a couple times to the on position, fuel started spraying out! why is it doing this? i threaded the inlet into the fuel filter as far as it would go with the recommended 27 ft lbs or so of torque, I for sure didn't overtighten it the outlet line, the one with the two washers and the banjo bolt seemd to be fine, no leak. So do i need to put some kind of sealant or what on the threaded line? HEEEEELLLPP please
Fuel Coming Out!!! Whyyy!!!
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
i just dont know why its doing this? i even took it off the clamp to thread it so it would go on straight. is there some kind of seal that needs to go on the threaded fitting?
i just took it ALL apart and put it back together again, its still spraying fuel everywhere. I have no idea how to fix it. Did i break a fuel line?
fuel spraying out of where?
WATCH THE SPEED CHANNEL?...HATE NASCAR? SIGN THIS PETITION!!!
Originally posted by jRbuMpNo one hates black people like black people hate black people.
it looks like its coming out of the fitted threaded line, the one that feeds fuel into the filter. And when I took it back apart, there was fuel inside the filter so nothing is blocked or restricting the flow
yeah but doesn't that 17mm bolt (vertical nut) have a hole in it to allow the fuel to pass through it? so if you tighten it too much then that'll make the hole not line up? this filter is an autozone one, im just wondering if i should go and return it and buy a honda one
tighten it more. were the threads all clean when you put it togeether?
should i go as tight as i can? because the chiltons manual said like 27 for the threaded one and 16 for the 17mm one, that isn't much is it? oh and the threads were clean, no marring or crossthreading on the line
well the vertical nut was Extremely hard to remove, i had to go get a 1/2in breaker bar from sears and put a 3/8in adapter with the 17mm to remove it. But was that because it was probably original? i can go tighter but i just dont wanna screw it up. but okay i'll try and tighten it more and checkLast edited by Losiracer2; 12-16-2006, 03:21 AM.
okay im going to try and return this filter and get another one, but have any of you tried to replace this fuel filter? it just seems like the fuel is coming out of the fitted metal part that goes into the threaded screw.
I would say tighten more until snug really snug but dont overtighten. Usually thast what I do I ignore torque specifications unless I have the motor apart and decide to build somethin.
