Front Motor Mount 5Spd vs. Auto Same?
    Front motor mounts for a 90 Accord, are the 5Spd and the Auto the same part numbers? Should be, right. E-bay ad states the mount is for an Auto and I've got a 5 Spd. I should be cool, right. Just a poor write up on the e-bay ad I guess?
    After 17 years and 208K miles, I'm not "tuning" my CB7, I'm "restoring" a CLASSIC.
    they are different part numbers. you can use the auto, its just that the manual can handle the torque of the engine better. i got a manual one from ebay myself. well at least the dude stated it was a manual. i will find out sooner or later once i install it.
    91 Ex CB9
    JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
    W.I.P.
    p72 ecu on Hondata
    To Come
    Weight Reductions
    R33 or R34 front end
      it should be the same.
      COMMENT MY RIDES!!!!
      91 blue accord ex 4 door automatic
        check out these two links. number 15 is what you want. like i said, they are different.
        manual
        https://www.hondapartsdeals.com/hond...omponent=B++47
        auto
        91 Ex CB9
        W.I.P.
        p72 ecu on Hondata
        To Come
        Weight Reductions
          flight's right, manual one is stiffer. auto ones usually have those two rubber covers on either side between the bracket. they are interchangeable, but not the same.
            Thank you boys (girls?).
