holy shyt crazy tach (help)
    ok i was havin a friendly race with a buddy of mine and at 5500 when vtec is supposed to kick in my car started stuttering and the tach went on crazy mode i checked my grounds and the vtec signal wire and the pin outs on the ecu everything seems fine if you can think of anything please help
    thanks justin
    kms-fab.com repin the 513
    tuned1.com
    sleeperautosports.com
    i will build another frank
    maybe this might point you in the right direction....
    http://www.cb7tuner.com/vbb/showthread.php?t=62687
      no cel / all wires are hooked up/ its a chipped p28 untuned/ oil was just changed 1000 miles ago i dont know what it could be
      tuned1.com
        check your alternator? make sure its tight. i had a similar problem like this, and turned out my alt belt was loose.
          ok...untuned p28...What map is on it if you didnt chip it that could be why. I would check the igniter but if its that high of rpm since oyu say you were untuned what did you do.
            check your wires on the distributor one of those wires is a tach wire make sure they r not touchin or exposed and also check the distributor i had a prob similar to that
              i had a p06 chipped it threw codes so they(sleeperautosports)traded me a p28 chipped it came out of a turbo'd prelude there is no fuel cut off no knock no o2 i have had this in my car for like almost a year this is the first time it has every done this
              tuned1.com
                ok its running off of a turbo prelude and did they revert to a stock map. If your running that turbo prelude map your gonna fuck some stuff up or your car is gonna run like shit.
                  was the tach jumping around like crazy? or was it matching what the car was doing? if its just random, it sounds like it might be the ignitor in the distributor? thats where the tach signal comes from...
                    when my f22 did this it was the distributor....replaced the dizzy and have been fine since...it would do it everyonce in a while until it just totaly fcked up one day
                    My Members Ride Thread
                      thanks guys for all the input im gonna test the pieces in the dizzy and the ecu was remapped i believe and the rpm's would go past the 8k mark as soon as vtec engaged
                      tuned1.com
                        Rpms would go past 8k mark? Stock fuel cut for the h22a is 7500 or 7800 YOur not making any power past 7200.
                          i think he ment when it went crazy ...not undernormal conditions
                          R.I.P. 6-10-07
                          (\__/)
                          (O.o )
                          My Rotor DIY
                          I'm not perfect i will make mistakes if i do just point it out to me
                            right as soon as i hit 5500 the needle would go past the 8k mark but the car would pop and stutter until i shift and get out of vtec mode and the ecu doesnt have the stock fuel cut on it anymore
                            tuned1.com
                              this is my setup i have a h22a4 out of a type sh and a regular h22 trans chipped or remapped p28 and my own custom intermediate shaft to fit the block
                              tuned1.com
