relay
    relay
    so last night i was looking at my car.i checked all the fuses under dash they were fine.i checked the ones under the hood and found a few blown fuses, like interior lights and stuff like that, but i notice i had no cooling fan relay.that could be why it overheats a little. but when i shut the car off i hear the fan come on.could i get that relay at advanced or autozone i would i have to order it somewhere. whenn i was driving to work this morning i was in 4th gear just coasting down a hill and when i got back on the gas it had no power at all. i would hit the gas and the rpms just went down.so i pulled to the side of the road shut it off for a minute then started it and it was fine.thats thee only time it ever happened.any thought on what it could have been. thanx for any help :P
    Damn
    It could be a number of things.... You have to have a starting point.... Did you check your Batt Cable so on and so forth.... When you order a main relay it will take about 2 days... I went and got mine from a local salvage yard...
    My Members Ride Thread ( Do It )
      Im not sure about your relay situation, but the cooling fans turning on AFTER you shut the car off is normal... 9 out of 10 cb7s do that.
        its something automatics do.
        you could try autozone, but a junkyard would be cheaper (or free...). if neither, the dealership.
          i have checked the battery cables and they are fine.i also got new plugs and radiator hoses.im doing the distributer cap and rotor today and on monday doing the thermostat and fuel filter.should i try adjusting the idle speed.it idles at 1500 rpms.i would scann it cuz every once in a while the CEL comes on but everytime i hook it up the scanner doesnt turn on.the scanner works fine just not on my car.i also tryed to jump it with a paper clip but the CEL just stays on and doesnt blink
            wow....
            Take a look at your engine ground as well.... Did you put your engine in or did someone do the work for you?
              Is there a thread with all of the fuse/relay locations and functions?
                the fusebox covers have diagrams, theres a fusebox in the driver kickpanel as well as in the corner of the engine bay.
                  i bought it a couple of weeks ago and just fixing a few problems before fixing it all up.when i was replacing my distributer cap and rotor today i noticed a hose was not connected.its suppose to go to the purge control valve on the charcoal canister.i cant put it back on because someone broke where you connect it.what is the purpose of the charcoal cannister?could that be why the car is running bad?should i plug that hose up untill i get a new cannister?
                  TKS :P
                    Thanks, I'm trying to figure out the foglights; they're not coming on at all.
                      TKS :P
                      I think your ride should be fine with/out the charcoal cannister plug up. I think that is for smog/emission readings..... I could be wrong...
