Cylinder Head Options for f22a1
    i only heard about this and i want the run down... the f22a1 is a sohc and what can you swap in?
    dohc stuff?
    h22 or h23?
    f22b stuff?
    do they just bolt in with no mods?
    whats everything i need before i do this? ex. valve cover... etc...
    i researched but some things still arent clear
    Be Clean
    F22A6 intake manifold and throttle body or h23 intake manifold and throttle body..
    DA FASTEST ACCORD IN QNZ
    The H-series potential only begins where the B-series ends.
    83 Porsche 944 Black - Sold (my first)
    91 VW Jetta GL Red - Sold
    95 VW Jetta GLS VR6 swapped Green - Sold
    90 Accord EX 4dr Navy Blue - Sold
    91 Accord SE Gray - Stripped N Junked
    92 Accord 10th AE Green - Sold
    93 Accord LX 2dr Frost White - 4 sale
    90 Integra 2dr JDM B16 White - Sold
    93 Accord EX 4dr Black - New Toy
      You can also use a H23 head..
        h23 cylinder head, throttlebody and intake manifold is a direct bolt onto my f22a1?
        how much horsepower will it make?
        do i need anything extra along side for example more oil than usual?
        does it really really work? my sohc to a dohc???
        Be Clean
          what exactly have you searched, and where?
          here is one of the many write ups made on this topic
          http://cb7tuner.com/vbb/showthread.p...ghlight=h23%2A
            these threads are all over the place.
            "Up Down, Slide To Slide"
            Members ride thread- ]http://www.cb7tuner.com/vbb/showthread.php?t=63019]
              if i do swap this, does the stock header still fit?
              Be Clean
                yes.
                h23/f22a/f22b dohc are the same exhaust port patterns.
                  so then these would work than? ebay "h23 IM"
                  question: there are two parts. whats what? this is the intake mani right? whats the other piece called with 8 openings?
                  Be Clean
                    top half is the plenum, bottom half is the runners. you sure you want to try a head swap? you need to take the timing belt off and swap timing gears and the like...
                      oh for real.... but do the h23 plenum/runners fit on the f22a? (are f22b = h23)?
                      .... the head swap seems worthless now -- the entire swap seems easier.
                      Be Clean
                        That is a one piece manifold...only problem with that is the runners look waaaay too short; that IM is designed for turbo applications. You may be able to lengthen the runners with some cutting and welding but eh...
                        As far as head swaps...the A1 head flows pretty well from what I know. Get a regular H23 intake manifold/TB, A6 or Delta cam, Ebay header and get a tuned P06...your car will run strong as fack. I had an F22A6 with an H23 plenum and my car ran pretty hard till it spun a rod.
                        Originally posted by lordoja
                          is your car running yet?
                            Nah...I gave in and took it to a shop. After hooking everything up we tried to start it...there was fuel, spark and it cranked but wouldn't start. We took the VC off and the cam gears out of alignment, suggesting the timing belt skipped a tooth. So I bought a belt, and we were gonna put it in, but DoctorCipher never came back, so I just towed it to a shop. I'm gonna call them now and see what the deal is, they were supposed to look at it today.
                              ok new question
                              for the f22b/h23: can the f22a tranny and ecu be used?
                              the motor is drop in and go right?
                              Be Clean
