for my 93 ex what throttle cable do/can i use for h22 swap?
throttle cable ?????
i have a 90ex i would figure its the same but i used my stock cable and ajusted all the way back its been working for me since last yearU dont work U dont eat
U dont grind Udont shine
1st car 90 CB7 lx auto coupe
present car 90 CB7 ex clutch coupe
1st motor f22a12nd motor f22a4
present motor JDM H22a with m2b4 trans
Originally posted by bluepearldreamzi actually have the same issue, the stock one seems too long, i have the prelude one also though, i gotta see if thats better fitting...U dont work U dont eat
STock cable works as mentioned. I would think the teg ones would be a lil short but never compared em. But stock works just as well. Be sure to adjust it right though so the throttle doesnt hang open a bit thats what happened to me when it would rev to 1500 then drop down to 700.
different CB's came with different length cables, i think auto ones are longer or something? but either stock one works fine, just the shorter of the two you need to adjust the nut all the way back..
Yeah the auto cable is a little longer bc the throttle rotor is bigger around on an auto. The throttle rotor on a manual is alot smaller. I guess bc there's only one cable mounted to it, as with an auto theres two. Only reason I know this, is bc I'm in the middle of a 5-speed swap and wasn't sure which gas pedal to use bc the end of the throttle cable that attaches to the pedal is different between autos and manuals.
Never underestimate a 4-door Accord
