what can happen if I use my car with a cracked open timing belt cover? does it have any negative effects? I craked mine while changing the crank pulley.
timing belt cover
as long as it isnt in the way of any of the belts, it will WORK fine... but it wont keep dirt/water out of the timing belt area like it should. how bad is it? you could always just clean it up and put a bit of JBweld over the crack.
Originally posted by JCtothaflowI Dont Think Its That Bad But I Noticed Iol Near The Crack, Is There Oil In There? Or Is It Just Another Leak?
