Radiator and Condensor fan motors...same??
    Ive tried searching and havent been able to find what Im looking for.
    Are the radiator and condensor fan motors the same? My condensor fan is out and would like to know if I bought a used radiator fan if the motor would work in the condensor fan.
    Thanks guys.
    Call up Honda and ask them? or go to local parts store and see if the part number is the same.
      if you mean the two fans you are using in the car, no they are not the same, i believe the condenser fan is metal and blows out, the radiator fan is plastc and blows in.
      also the radiator and radiator fan are interchangable with certain preludes
      but correct me if i am wrong
      Sold my baby
      saving for an Sc300!!!
        i also believe they are different. i have a condensor fan assembly-if interested pm me.
        if ur 555 then im 666
          definately different.
            Ok...thanks for the responses guys..but it seems Nail05 is the only one that saw "Are the radiator and condensor fan MOTORS the same? My condensor fan is out and would like to know if I bought a used radiator fan if the MOTOR would work in the condensor fan.
            Seems I have found the answer to my own question though. The physical motor IS the same, and I have found a brand new one for $36 at www.partsamerica.com (which is the "vendor" of sorts for Advanced Auto) so I will be getting it there. All I will need to do is splice in the connector from my non-working fan.
            And both fans blow towards the engine by the way. It would be pointless for a fan to blow towards the front of the car as the car is moving forwards. It would be working against itself.
            Thanks for the help guys.
              i wasnt aware that the motors could be separated from the main frame piece...
                Yeah...says so right in the Haynes manual. Im probably going to pick one up this weekend depending on the check. I have to do front brakes and oil change, and cv joint change...so may not have enough yet. Supposed to be pretty nice for the next week...so not sure that I need it yet. Shoot...went through the 100+ degree summer with it out..so shouldnt be to bad for the fall.
