Shifter sticks in park
    automatic, 92 accord
    it doesnt like to be pulled out of park sometimes? runs super
    does the shifter need some ky?
    take off the plastic around the shifter and you will see a cylinder that locks/ unlocks your auto shifter in park, check that. I would hook up a multi meter to it and see if its getting a signal. if it is getting a signal when the key turns, and isnt working then you should replace it. Have you checked all of your fuses?
    spin city
      Neutral Safety Switch?
        you might want to check the sensor on the foot brake lever. *have to get on your floor board to see it.
        i had a 91 with the same problem and after a little cleaning and some persuasion with wd-40 it started working great.
        chris<pixelmonkey>
        there were blanks in that gun!
          does it feel stiff and takes a good tug to get it out of P, or is it semi loose its just locked in? if its getting locked in by something, its probably the pedal switch or the solenoid on the shifter like mentioned above, but if the shifter moves, just its sticky and jammed and hard to move, its probably the shifter cable rusting up.
            If your TCU is failing it will cause this also sometimes, mine did just before it failed.
            The 90 Accord 4DR Sedan my son and I are building.
