Clutch Question
    Clutch Question
    Hey guys.
    Going to be putting my new clutch in soon..
    Search everywhere.but..
    Does anyone know the OEM Part number for the throw out bearing. Ihave an f22a1 5 speed prelude.
    Also was wondering..can i reuse the flywheel and pressure plate bolts.
    Is there anything else i need to replace when changing the clutch?
    1992 Honda Prelude S - Swapped F22A6 - Turbo 16g Powered!
    Mods: 3" Exhaust,450CC Injectors, DSM Manifold, DSM Ported 16g, Stealthmode Oil Line Kit, RFL BOV, JDM Black Housing Headlights, Clear Corners, Tinted Tails, Forbidden Short Shifter, Front Mount Intercooler, Chipped and Tuned P06 ECU - Tuned With Uberdata, Lowered 1.7,6 Puck Clutch"
    PARTING OUT F22A1
    throw out bearing
    part 5 on this page.
    spin city
      yes, u can reuse bolts and pressure plate.....if pressure plate aint that bad, u might consider getting it resurface, but not necessarily unless its really bad..!!
        if youre goign to an actual dealership to buy it, they dont need the part #s, just tell them what you need and they will get it for you.
        and yes, you can reuse the PP and FW bolts - otherwise youll be spending $60+ replacing just them...
        not much else inside there to replace, besides the clutch and pressure plate, which should come as a kit. and make sure you resurface the flywheel, thats very important.
        only other thing i could suggest replacing is the rear main seal, since its right there... at least check if its leaking while the tranny is off.
          Im getting a 10lb flywheel...XTD stage 3.
          Went to that page..there is 2 number 5's ..hmm
          PARTING OUT F22A1
            WHich part number is it?
            PARTING OUT F22A1
              i cant quite remember for sure or not.. but i think its recomended to use lock tight on the flywheel bolts... and make sure to TQ those to the right specs!
                Guys which part number is it? I really want to order it before tommorow.
                There is two number 5's.
                Does it matter which one?
                PARTING OUT F22A1
                  http://www.hondaautomotiveparts.com/...CLUTCH+HOUSING
                  PARTING OUT F22A1
                    figured it out. Both part numbers are made by OEM manufactures to honda spec
                    PARTING OUT F22A1
                      props on puttin a real clutch in it. just did an h22 swap for a younger guy-(kid,16,daddy payin for it) newayz- he didnt want to wait to put a REAL CLUTCH in it. summit is like 1hr away-maybe. almost didnt finish the swap. his loss-not mine.
                      if ur 555 then im 666
                        Got the new clutch in..i like it alot..especially the lightweight flywheel..it rev's up so damn fast!! And the clutch grips like a MOFO
                        PARTING OUT F22A1
