can anybody tell why a cv joint wont go in all the way? i have an h22 lsd tranny and its just the drivers side shaft thats giving me the headache.
CV joint won't go all the way in
Its prob not lined up with the Splines. Turn it a lil and push it in or you can just grab a soft face hammer and tap it in. SOFT FACE not a REGULAR hammer.
A regular hammer wont hurt it unless you somehow hit the CV joint itself(dont really see that as possible since the boot is in the way and the bearings are inside the cup/housing). I've never had a problem with this method.-Kevin
1988 Honda Civi- D15B VTEC Dac Biet, my "race car"
1992 Honda Accord LX: DD until I finish school
You use a regular hammer to bang it in you risk mushrooming the axle nut side UNLESS you screw on the axle nut flush with the threads and hit it but I still dont recommend it. I just twisted mine a lil and pushed it hard and it went in. I rarely use the hammer.
There is a ring on the spline, that when you press it in enough, it compresses, and when it goes all the way in, the ring uncompresses and snaps into a groove.
I never said anything about hitting the actual spline that sticks out(why would you hit that to make the axle go in?). Plus, if its already half in, theoretically it's already aligned(unless the splines in the knuckle or shaft are messed up).
Is it the part that goes into the knuckle or the part that goes into the intermediate shaft that's giving you the problem?
I had somewhat the same situtation on my CRX, the driver side went in easy, but the passenger side took a little more work.Last edited by K2e2vin; 08-08-2006, 11:11 AM.-Kevin
happens often. i usually put the end of a breaker bar on the edge of the CV joint (yes, itll be sitting on the rubber boot), and tap on the back of the bar with a small sledge. neither the edge of the CV joint nor the breaker bar is sharp enough to cut into the boot, and it usually gives enough force to get the snap ring to pop all the way in. i have done this tons of times and never once hurt the boot, just be careful.
Originally posted by d112crzytry to get the axle as level with the ground as possible. sometimes you just have to wiggle them bitches in.
