Is my car trying to tell me something?
    ok so there is a little colored squre on the tach that says maintenence (sp?) required under it. Well right under I got the oil changed (valvoline max life) the little square turned an orange-yellow color. Well now on the left hand side of the square is turning red. Now the check engine light has not come on ye, but should I be concerned? Will just having this little square change give a code on a scanner or what? The car sounds and runs fine, i see nothing obvious under hood either. Help me please?!?!
    1992 Honda Accord DX
    Coupe 5spd
    2.2 liter I-4 (code: F22a1)
    125hp @5200 rpm 137 lb/ft @4000 rpm
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    Its no big deal..that changes to yellow and then red every few thousand miles to remind you about oil changes. and the like.
    you can reset it by sticking your key into the little slot in the cluster
      Reset it with your key no biggie. Im not real sure but i think it turns red after 5k miles.
        i believe its 5k yellow, 7500 red. i covered mine with a strip of blue electrical tape.
          ok where is this magic slot thing? Bear in mind its 10 at night and all I have is a little flash light to go on
          Coupe 5spd
          (\__/)
          (O.o )
            far left corner of the gauge cluster.
              ok went out and did it, yay, I have a green light again. Also I know this is kinda left of center but how do you change out the dome light bulb. I don't have one thatworks right now and it is starting to bother me. I normally wouldn't ask but I have had a problem with snapping plastic pieces trying to forcethings the wrong wayso, how do you do it, and which light do Iput in there?
              Coupe 5spd
              (\__/)
              (O.o )
                I always wondered what that was for. Now I know. Thanks for this thread.
                  for small int pieces like that, i find it best to use a thin sharp knife(just use your noggin and dont point it towards yourself or another) and just pry it.
                  And Mike..thats great way to just bury yourself in denial im thinking of covering mine in translucent camoflauge tape soon....
                  Originally posted by Jarrett
                    I feel so special now, hooray for me I made a useful thread
                    Coupe 5spd
                    (\__/)
                    (O.o )
