What is the fitv and how do I clean it?
    Hey, back in my tune up questions thread someone menshioned the fitv and this is the only decsription I got of it -- "nevermind i found what it is and where it is located. it is the fast idle air control valve located at the right of the iacv." can anyone explain what it is in more detail and how to clean it, or point me to a diy thread? I can't find anything on it.
    if u have an f22 then its the upright cylindrical-looking valve located on the right side of your IACV valve. It has 2 collant hoses connected to it. If your idle seems to surge when the car is warmed up then this could be your problem. Remove the top plate on the valve (2 screws) and tighten the white plunger all the way). Put the plate back on then voila youre done!
    ...adjust accordingly
      Yes, it's a f22a1, sorry for not mentioning that.. 92 accord lx coupe. I know exactly what you're talking about too..
      http://img.photobucket.com/albums/v3...r/DIY/iac3.jpg
      I got the pic from the IACV cleaning diy.
      The black thing on the right of the IACV. The screws are on the black thing, after I unbolt the IACV and then theres a white thing that I tighten all the way.. okay. Is it possible to mess up my idle doing this?
        the thing youre looking at is the IACV... its the thing to the right of that, its only partially visible in the picture you posted.
        i found this searching google: http://www.emotors.ca/Articles/97.aspx
          Ok forget the iacv valve (the one pictured in the pic) focus on the valve on the right. The top plate is bronze colored. There 2 screws, remove them, youll see a white plunger that is made outta some plastic. Theres 2 indentations on it. Tighten it until its firm but not ridiculously tight. This could possible lower your idle but not 'mess it up'. Youre idle should be 700+-50rpm without a load on it. If its not then mess with the idle adjust screw located on the throttle body near the top for fine tuning.
            Alright, got it. Thanks a lot guys.
