clutch lines
    clutch lines
    i just replaced my clutch line because the old one had a hole. however i tried to bleed the system again with the ne line but it still doesnt build up pressure anyone know wuts rong?
    Hold On Not Done Accelerating
    Had One Never Did Again
    is it 100% completely sealed and tight, and are you following the directions in a repair manual perfectly?
      yes well i just replaced the lines and had to put a few extra bends in it but the fluid still flows to the other end. i just dont no y it wont build pressure. everything is really tight
        it only builds pressure if the bleeder screw on the slave cylinder is closed...
        ...again: are you following the directions in a repair manual perfectly?
          You would think that you would see the leaking fluid somewhere. Anyway, move from one end to the other and tighten everything while looking for the leak. If you can't solve the outside leak then check on the internals of the clutch master and slave cylinders, the seals might be leaking.
            i think i might have pressed the clutch while the clutch line was out when i was repacing it....would that make a difference? i no that the master slave cylinder is good for sure.
            mike....the bleeding procedure is exactly like doing the brakes right? i pump the pedal a few times then hold down n bleed. tried it so many times but the clutch still doesnt build pressure.
              i just checked all the lines. disconnected them n pressed the clutch and all the lines are fine. the fluid comes out evrytime i press the clutch. i checked all the lines from the master cylinder all the way to the slave cylinder. then i pumped the clutch pedal almost 100 times n still no pressure. i dono wuts going on
                When I replaced my slave cylinder I had this problem. The pedal was dead and I couldn't get any pressure at all. Try pumping the slave cylinder by hand and keep the resivoir cap off so you can keep it filled. Worked for me after about 5 times. Then when you get some pressure bleed it the proper way with the clutch pedal and bleed screw on the slave. Good luck.
                Short
                  what do u mean by pumping the slave cylinder by hand? do u mean just moving the ribber piece?
                    Well when i changed over from auto to manual, it took a long time for me to build up pressure. I thought that i had forgotten something and was like this sucks. But it finally built pressure after about 30 mins of pumping and bleeding. No joke.
                      ive been tryin for soooo long. the whole day i was at it, tryin to bleed the clutch. but i will try again tomorrow and i will try what short1 said.
                        yeah, you have to keep on pumpin even if you feel like you've already pump so much. I remember this feeling and I almost quit because I couldn't build pressure and it took so long to get it. Have another person to help you pump and for moral support
                        Sky rockets in flight..... afternoon deeeelight!!
                          The seals are liking bro!!! i can almost bet...
                          [SIZE=4] IMPACT
                          [IMG]http://www.imagestation.com/picture]
                            Ok, there's a piston coming out of the slave cylinder that is covered with the rubber. It goes onto the clutch fork? I think it's called. Pump it by pressing on the clutch fork to push that piston in, you will see the air bubbles coming out of the resivoir. Do that a few times until you get pressure at the pedal.
                            Short
                              Short
                              thats exactly what i did today. i noticed the air bubles comin out from the resevior and the piston did start to get harder/build pressure. when i went to pump the clutch pedal, it was still dead
