Hi guys, my first post. Some of you "might" know me as maxsideburn from the 3geez forum. I've just decided to buy a 90 coupe and I need to know what could be causing this problem.
Here's what's going on now. The car will start and idle roughly, it will die if not revved up until warm. Once it's warm it still continues to rev up and down a lot by itself.
Now considering my knowledge of 3G Accords I'm assuming this is one of three things, EGR valve problem (stuck open, or something along those lines), vacuum leak somewhere on the intake manifold, or just some sensor completely screwed.
As a side note I should also mention that the exhaust is screwed, pretty much everything from the cat-back is falling apart and leaking.
