New And Need Help
    New And Need Help
    Hi Im New To This Site. Hoping Someone Can Help Me With A Tech. Problem. On Start Up My Car Idles Up And Down Until Warm Up Then Its Normal And I Dont Have A Check Engine Light On. What Can Caus This And How Can I Repair The Prolem, Its A Lx Model
    TOPEND PERFORMANCE
    R.I.P SPIRO
    Its your high idle valve, I had the same prob, get it replaced, or make sure all ur hoses are secured tightly then see if it still does it. It is near the top of the intake manifold.
    "Mind Over Matter, If I Don't Mind, It Doesn't Matter"
    http://www.cardomain.com/ride/2049267
      Thanks I Will Do That... I Hope Thats The Problem Cause It Drives Me Crazy Hearing It Especially That My Car Has Headers With A Straight Pipe So Its Loud And Annoying
      TOPEND PERFORMANCE
      R.I.P SPIRO
        the triangular cylinder thing on the driver side of the intake manifold is the fast idle valve... take the three screws out of the top and youll see a white/grey plastic ring with an egg shaped plug in the center. twist the plastic ring clockwise to tighten it all the way down. reinstall the cap and you should be good.
          Oh Ok I Will Do That As Well.thanks
          TOPEND PERFORMANCE
          R.I.P SPIRO
