Hello all...I am building a H23 to install in my Accord, I installed the head gasket and torqued it down. Later to find that the cylinder head has a crack in it. My question is can I reuse the head gasket. The engine was never started. The head gasket is a Honda gasket. Any help would be apricated. Thanks in advance...
Head Gasket Question???
not that i recommend this, but when that happened to me i bought a new autozone headgasket, slit the bottom edge with a razor and swapped the clean used one back in. sealed it with a thin strip of tape, then i returned it the gasket is packaged between two sides of cardboard, so you cant see into it anyway.
