Mounting tranny!
    Mounting tranny!
    Does anybody know how to mount a 94 accord ex tranny into a 93 accord? do you use the 94 accord tanny mount with the 93 bracket or do you use the 93 accord mount and bracket. If anyone has done this please helpme out, pictures would help tremendously!
    ~~~ Never Drive Faster Then Your Guardian Angle Can Fly ~~~
    I didnt think the years were compatible...I know 90-93 are compatible but other than that, I am not sure.
    07 Kia Sportage (Her car)
    91 Accord EX (My car)
    04 BMW R1150RS (My bike)
      getting the tranny on the motor should be easy, getting it to hang from the chassis is the trick....
      Depends on the motor... should be a F series right?
      I cant Slam further. The ground refuses to get any lower.
        youll find 2 unused tranny mount stud holes on top of the tranny, drill them wider with an 11/32" drill bit and tap them with a 10x1.25mm tap, and you can use them to put the 4th gen accord mount on the new tranny, and everything will bolt back up like stock. this is the method for installing any 5spd 4cyl 94-97 accord or 92-01 lude tranny.
        assuming both are manual?
          are there any advantages of running the 94 tranny?
          RICE COOKA!!
