Doing h22 swap need tranny
    yeah i was wondering a lot of people been doing an accord tranny onto a h22 block...do you guys recommend it or should i jus stick with tha h22 tranny
    yessa im back in action
    Future Plans:
    undecided on motor
    USDM manual F22 tranny swap
    Tein S tech springs
    Koni Shocks
    I know for a fact Aero has a F22 tranny on his H22. The H22 tranny has shorter gears, as with the F22 which has long ass gears.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      it all bolts on the same, but i cant stand the laggy feeling of an h22 with an F tranny...
        As I am no tech guru, but having the F22 tranny and the H22 engine be better. I am assuming th elonger gears will enable higher speeds?
          youll probably end up driving the same speeds around town and on the highway whether you have an F or an H tranny, but yes with the longer gears, youll be able to go faster in each F gear as compared to the same H gear... youll have to shift a bit sooner each time with the H tranny but the acceleration is much nicer. though i hear that in a drag race, either one will end up giving you the same time, because where the F lacks in acceleration, it doesnt have as much wasted time shifting as the H would...
            Chances are you'd have to suck really fuckin' bad at shifting that h22 trans for that to be true. The difference is like night and day.
              well my car is gonna be all drag car...so imma be going for a drag setup
              Future Plans:
              undecided on motor
              Tein S tech springs
              Koni Shocks
                Im runnin the F tranny. Honestly I really dont like it. The H tranny will be in pretty soon if I can find an M2B4 for cheap if not im gonna have to settle for some non lsd replacement. Gets pretty good gas mileage though. And anyway drag doesnt depend on higher speed its who can get there faster.
