My car tilts?!? What!?!
    I keep on discovering more and more problems with my car. So far they've been relatively minor, but troubling nonetheless.
    My latest "discovery," my car tilts slightly to the right/driver's side. I thought I was crazy, until I got a leveling thingy out and found that even on ground that slightly tilts to the left, my car still tilts to the right.
    What the hell is this crap!!? Does anyone have this problem? Or know the solution?
    1991 Honda Accord EX (Canadian)
    replace your blown shocks
      mm agreed.
      Audi A4 2.8 Quattro Sport
        same problem, need to replace shocks is the answer.
        and while your at it, get performance ones b/c doing it over twice is a pain in the rear-end.
        good luck
        (RIP)1993 LX Sedan
        Frost White Crew Member #36
        JDM Beating Stick Owner #1
        My (old) Ride
          x3
          MYCB7.com
            .....You guys suck. I hate you all so much....SO much.
            Well, not really. I'm just UNEXPLETIVEINGBELIEVEABLY pissed off. I can NOT afford this.
            Now, I should buy a Digi-Tally-Picture "machine" just to show you guys exactly how much the car is tillting, or conversely, how much is isn't tilting. Whatever, the bottom line is it's really not tilting thaaat much.
            Here's a mental picture: You know those leveling things (found in any wood-working tool box...probably?) that have the liquid with the air bubble inside? Well I used one of those, and about 1/8 of the bubble (if that) is past the little line on the left (indicating tilt to the right hand side). But it is definitely tilted.
            Does that make ANY sense? Am I completely insane and deserve a swift slap to the face?
            Anywhooozze, I just need to know how long my trusty steed can function in it's current predicament before any kind of catastrophic failure occurs. Or is this more of a "your car looks totally ***, but isn't actually all that fucked" moments?
            Thanks for the replies!
              Ok first off, stop with totally useless and random jargon.
              second, I've been riding around in mine for a few months now, and I haven't had any problems yet, but I bet my tires aren't wearing right.
              If you have the money, replace the stuff; if not just deal with it how you see fit.
              (RIP)1993 LX Sedan
              My (old) Ride
                I'm pretty sure my car's lopsided...it rides fine though
                Originally posted by lordoja
                  Do I sense some sarcasm?
                  I say if you can't afford fixing it. Go to a junkyard and take an entire shock assembly, whether the front is fucked or the rear is fucked. Will be your cheapest route. Do the labor yourself. There is a suspension DIY on here. Good luck!
                  MYCB7.com
                    In addition to your shocks being worn out, your springs have probably sag a little more on the drivers side because of the 12+ years of someone sitting there all the time. It's an old car. Deal with it.
                    Honda-Tech Username: Lostcb7
                    The cb7tuner.com OG.
                      your car isnt actually all that fucked.
                      my LX was like that, tons of old cars are. id just deal with it until you start to actually have problems from it. shocks may not be blown, may just be worn out and wimpy... springs may have sagged like jdmcb7 said... its an old car, it happens.
                        Haha, very true.
                        Do you have pictures of your car you could show?
                        MYCB7.com
                          Werd. Springs alos sag over time, especially cheap egay "coilovers".
                          - Zipcreature
                          Awesome!
                          CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                            My front driver's side always looked lowered when I had the stock suspension in. When I took the stock suspension out, I had discovered that 1 spring had a curve in it, allowing that side to sit lower. The other 3 were straight. My shocks were fine, so it may be a bent/damaged spring.
                            It's not all that bad, it may not even be your shocks!
                            Dan
                              My car leans to the drivers side as well. Even after replacing the stock springs and struts with Eibach Pro-Kits and Tokico HPs (blues). I have no idea why, but I'm considering getting Tein SS coilovers so that I can correct it (no way would I install cheap ebay knockoffs, don't want the hassle).
                              Originally posted by Junior Smurff
                              Nevermind guys, google search works wonders!
                              I don't have road rage, my car just goes faster than yours!
                              Accords are for winners. And Grandmothers. But mostly winners.
                              I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
