I have a friend thats junk'n a 93 lude. Will the lude rear disk swap directly over to my 91 Ex coupe? And will i be able to do the sameto the lude..swap in drums..vice versa.Thnx
Help with rear disk conversion.
unfortunately, no, they wont fit :\
There is a thread in the DIY section.
Here is a link, the thread has the same name, in case you need to find it again.
SUSP: rear disc conversion
Yes, the 91 SE rear discs will work for you application. You can use your control arms if you really want to, but it is easier to just replace the entire rear suspension.
The rear disc assemblies from 92-93 EX/SE's will also work.
There are some 5th gen Accord rear suspensions that will also work, although I have personally encountered some that wouldn't as well. The 92-93 EX's are becoming fairly common in the junkyards, and are probably your best bet.
