How do you 'bench bleed' a MC? The only bleeding I have heard about is bleeding the calipers.
Master cylinder repair with pics
when u buy a new m/c they include plastic fittings and tubes, you put the fittings in and loop the lines into the top of the m/c, then you fill it with fluid and keep pumping the piston. it circulates the fluid through the m/c and the bubbles bubble out. i have a couple pieces of bent brake line that i use
