f22b2 intake manifold
    will a f22b2 intake manifold be able to be a use on a f22a engine, because I want to replace for a1 manifold.
    Yeah, Preludes
    Why can't people just search OT to see if someone else posted the same random thread?
    do a search for intake manifold swap. you can use f22a6 or h23
    hold on to your butts
      yes, it will fit, but if anything, it will be the same as the stock a1 manifold. the f22b2 is kinda a peice of shit.
      -Mark-
      CB7
      CD5
        i know those will work, I'm just seeing if anyone has used these...
        Yeah, Preludes
          when my f22b dohc engine went i just put the f22b intake manifold on my f22a1 and i sware it gave me 10-15 horses
          so go wit the h23 manifold probly the same as mine
            so does f22b have dual runners?
            Yeah, Preludes
              F22B is not F22B2.
              JDM F22B intake mani should fit, as will the h23. f22b2 should too, but i wouldnt try it, the sensors and everything are so different that youll be wasting a lot of time getting everything to work.
              i have an extra f22a6 manifold (dual runners) if you want it...
                THE F22B2 MANIFOLD WILL NOT FIT AN F22A1 ENGINE and yes this manifold is a p.o.s the intake and coolant holes do not line up wutsoever but the stud holes DO to the f22a1. if u wanna be certain hit up a parts store and check the product numbers or if u can get them both together you'll see the don't match up worth sheit.
                4drs4morehores
                h23/f22 hybrid
                  you sure? companies sell intake manifold gaskets listed as F22/H23 applications for all 90-97 accords (which would include both the f22a# and f22b#) and non-vtec 92-96 preludes (f22a and h23), which would mean the intake runners and coolant port would have to match... ive never lined them up myself, it was speculation. within a couple weeks ill pick up the extra f22b2 manifold out of my friend's garbage box to see if the ports are the same hybridizer, have you tried it yourself?
                    Im sure they work. well, Im sure they work through the word of oneoffaccord, whom I trust with things like that. he said he put an F22b1 gasket onto the F22B DOHC head he sold me and that it fit. I was concerned about finding an IM for that head, and I was just going to use the F22b1 one until I could afford one (since thats the problem now).
                    -Mark-
                    CB7
                    CD5
                      yes ive been trying to put the B2 engine in my brother 91 cb for the past year and we've been running into problems left and right, i poured cooland into the engine w/ the a1 mani on the b2 engine and got a serious leak soo i took it off and noticed that the coolant holes on the passenger side do not match up also neither do the intake holes b2 are bigger. Ill try to take some pictures as soon as i have the time of the gaskets and their differences.
                      4drs4morehores
                      h23/f22 hybrid
