I changed my front struts about 8 months ago. reused rubber bits as they where good. I messed up one of the top strut bushing metal washers that spread the torque over the bushing. I replaced with a regular washer as a temp fix. I knew it was going to kill the bushing.
Anyway the bushing is cracked. I now have a replacement top bushing and washer.
The safety question is: With the strut mounted is it safe to remove the center nut to replace the top piece of the bushing and washer.
Will i be able properly torque the nut with it installed?
Thanks for your time.
edit: To be clear I am talking about the metal piece the center nut sets on and the bushing the metal piece sits on.
