I want to try building a homemade jet engine and I was wondering how high of pressure the CB7 fuel pump runs at. If it's high enough I can use it to pump fuel for the jet. Thanks!
How many PSI does the fuel pump pump fuel to?
Originally posted by Raf99 View PostOEM fuel pump is around 30PSI.
p.s... ever see http://www.colinfurze.com/ ? dude does a lot of crazy stuff with homemade jet engines.
I read the title and immediately thought
How much fuel could a fuel pump pump if a fuel pump could pump fuel.'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
Originally posted by domesticated View PostI read the title and immediately thought
If you completely block the return line from the pressure regulator, the pressure goes to about 60 psi.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Do a little math and you could interpolate the pump curve. Remember, higher pressure is lower flow rate.'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
