how can i make the most of my f22a1
    i have a stock f22a1 motor with automatic transmission, i have read that i can use a p12 from a preludeS 90-93 to give a nice little 10hp boost what are some other small cheap ways to pull a few more ponies out of this motor, i want to try and keep this stock motor for awhile but make it a little fun at the same time
    Welcome to the site, please brush up on the rules and familiarize yourself with the search function.
    http://www.cb7tuner.com/vbb/showthre...ghlight=%24500
    http://www.cb7tuner.com/vbb/showthread.php?t=188897
    http://www.cb7tuner.com/vbb/showthread.php?t=197109
      The second link is broken.
      BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
      BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
      Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
      CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
        Can't link to search results. They only last for a few minutes.
        92cb7pnw, this entire site is dedicated to cars that come with your engine (or variants of it.) Not to mention someone posted pretty much the exact same question yesterday!
        It's good that you've read enough to learn about the P12. At least that shows you've done SOME work on your own... but seriously... asking such a broad and generic question is practically insulting to the people you're asking for help.
        Here's a starter. Don't expect much more than this.
        P12 for the F22A1.
        H23A1 intake manifold, F22A6 camshaft, PT6 ECU (to operate the IAB system, and fuel correctly for the A6 camshaft.)
        Header - Bisimoto if you have the money, if not, a cheapie generic header works. Megan Racing is among the best of the cheap stuff. OBX is also decent. Add a 2.25" or 2.5" collector to a cheap header, and you'll see decent gains (that will also result in an overall cost of over $400...)
        Exhaust - 2.25" for mild F22A performance, 2.5" for more extreme. Keep in mind that the performance gains are usually directly correlated to the amount of noise made... so if it's quiet, it's restrictive.
        Intake - a generic "ebay" short ram intake with a quality filter from AEM, K&N, or Apexi will do just fine. Don't run the cheap filter, as it won't work well, and may lead to engine damage in time.
        Before doing any modifications, do a full tune up. Make sure your engine is healthy. Fix any oil leaks, replace all ignition components, change all filters, adjust your valves... Your F22A1 made 125hp at the crank when it was new. Chances are, that has dropped to about 110-115hp by this point. Assuming a 15% drivetrain loss, you're looking at 100whp or less. You'll see more of a power gain with proper engine restoration and maintenance than you would from most modifications... and when you do those modifications, the performance will be increased even more.
          Best bang for your buck that hardly ever gets spoken is a h23 or h22 transmission.
          02 Crv
            That's true. It won't make the engine any more powerful, but it'll make you accelerate faster. It would be pleasing to the butt dyno.
            A full poly bushing kit, anti-sway bars, good tires, quality springs, and properly matched shocks would also make the car more fun. You can use suspension upgrades much more than engine upgrades in the real world.
              Useable power is what it's about, when my tired 115hp/tq celica can out run one not due to power but gearing its pretty sad. Trans mission will make the biggest gain in not only the butt dyno but et's aswell.
              02 Crv
                It depends upon application, the time it takes to shift should also be considered, along with where in the powerband your gearing will fall into. If anything the biggest advantage for the op would be to get a manual trans as it will result in more power to the ground due to less drivetrain loss.
                  i wasn't trying to be insulting in anyway i really do appreciate the info, i actually already have taken the swap out myself and replaced all the gaskets and sent the head to the machine shop and got new stems and seals, every gasket on there is new, but being dumb and not thinking, i reused the stock head-studs and i now believe they are stretched because i have a slow leak out of the head, so i'm pulling the head back off and using arp head studs, i'll probably swap out cams, as far as the intake goes i'm not trying to convert anything at this time such as obd* i have big plans for this car for now i just want it to look like the f22a1 just a little more power though
                  and as much as i would love to have a manual transmission in there the auto has to stay in gotta let my lady learn to drive with it lol
                    Nobody is suggesting changing the intake manifold to an OBD2 unit. Merely saying an OBD1 H23A1 manifold will add a great deal of power. It has been discussed many many times on this forum.
                      o ok that makes sense, honestly wasn't really something specific i was looking for so it's not something i would have thought of i really appreciate the information though thank you
                        Fixed, don't know how that happened.
                          If it was something you knew to ask for, you wouldn't need to be asking for it, now would you?
                            very true, i was more so saying that's why i had such a broad question in the first place
                              Ditch the automatic, that is what sucking up the most power.
                              1992 Accord Wagon (RETIRED)
