stock vs aftermarket headers
    What's the big difference between the stock headers and aftermarket other than the clean look?
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=199548
    Flow. However there is also a difference between crappy brands and name brands to.
    Retro!
    Hater
      POWER!!!!!!!!!!!!
      UNLIMITED...POWER!!!!!
      (Throws Mace Windu off the ledge of the chancellor's chambers to his demise.)
        Originally posted by Jarrett View Post
        POWER!!!!!!!!!!!!
        MRT
        sneaky motherfucker
          Are they a good bang for the buck? Is it worth to pay 500 bucks for them?
            As long as you get all of your headers.
            My CB7 only has one header.
              To be honest depends. You have an H or F ?
              You're going to confuse some noob.
              Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
              den das al u ned u no dat u get wurs gas milge tho rite?
                Depends how much money you have to spear, If you got money burning a hole in your pocket spend $500. If you don't go with the headers they have on ebay, like most people do. [I think]
                I don't think they're is much of difference from the stock to an aftermarket i do have an a6 though so its almost the same setup, besides the deeper sound. I have an ebay header on my coupe and its utter crap when it comes to quality but it gets the job done, I wish I had my DC Sports from my last coupe still. It'd look cooler, plus more JDM street cred.
                  You're probably right.
                  91cbseven: Just go to your local JY (junkyard) and try to find an F22A4, pull that off and you'll have a nice upgrade to your current header (assuming you have an F22A1).
                    I have the f22a4 set up with stock headers
                    Sometimes I forget that 5 hp to a Engine that only had 130 to start with is good. That is almost a 4% horsepower gain!
                      5 hp to the crank maybe, by the time it gets to the wheels you're looking at maybe 1-2 hp. I wouldn't waste money on an aftermarket HEADER if you have the A4, unless you want something shiny for a few months.
                        Wow 1-2 whp is not worth 500 buck guess that solves my problem. thanks!
                        Any gains from header wrap?
                          Most likely no, unless you're for some reason running a really lean mix. The wrap will just make the header temperature raise since it's not getting "cold" air from the outside (not really cold cold air but you get the point, lower than the exhaust gases).
                          MRT: http://www.cb7tuner.com/vbb/showthread.php?t=197342
                            If you're talking about Bisimotos header, it gives you 15 whp.
                            But I think that's $900, so I'm not sure what you're talking about.
                            MRT
                            sneaky motherfucker
                              What? hows DC jdm in anyway shape or form? You do realize the dc is the same design as most of the generic's right? so looks are the same besides the coating.
                              02 Crv
