so I am replacing both my cv axles cause they are bad, and my whole front suspension but thats beside the point. I am also replacing the output shaft seals for preventative maintenance and one day when I got home from work my brother had installed the passenger side without putting in the seal. im kind of anal about this stuff and really want it replaced but now i cant get the axle back out. I have pry'd it like a mother with my biggest pry bar but it barely even budges..am i missing something? ive watched every vid and they all pop right out(for the most part) i have searched and junking the car/ beating the hell out of a brand new axle is out of the question. any help would be great. kind of want this done today. thanks a lot!
pass. axle removal help
Originally posted by biggmatt207 View Postso I am replacing both my cv axles cause they are bad, and my whole front suspension but thats beside the point. I am also replacing the output shaft seals for preventative maintenance and one day when I got home from work my brother had installed the passenger side without putting in the seal. im kind of anal about this stuff and really want it replaced but now i cant get the axle back out. I have pry'd it like a mother with my biggest pry bar but it barely even budges..am i missing something? ive watched every vid and they all pop right out(for the most part) i have searched and junking the car/ beating the hell out of a brand new axle is out of the question. any help would be great. kind of want this done today. thanks a lot!
Pretty solid video.
Axle really just pulls out. Sometimes its a pain in the ass when a seal goes bad, but it just pulls out. Prying can make it harder if you are just using a generic pry bar. If you are using some off brand pry bar, try pulling on the axle the opposite way to keep the splines straight as they come out. If you pry from one side, its just pushing the splines into the other and it makes shit harder. Honestly though, it should just pull out.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
went out and tried it with no success. here are some pics for reference on how i am going about this...
I am pulling the generic orange pry bar left to put pressure on the cv axle while pushing and pulling the snap-on to try to pry it out. this sucker is stuck in there good and I don't know why. time for work now but i will go back at it tomorrow. hope the pics help and i am not being confusing. thanksLast edited by Jarrett; 08-14-2012, 06:31 PM.
Originally posted by biggmatt207 View Postwent out and tried it with no success. here are some pics for reference on how i am going about this...
I am pulling the generic orange pry bar left to put pressure on the cv axle while pushing and pulling the snap-on to try to pry it out. this sucker is stuck in there good and I don't know why. time for work now but i will go back at it tomorrow. hope the pics help and i am not being confusing. thanksLast edited by toycar; 08-14-2012, 12:20 PM.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
when I did mine i had no problem, I accomplished this by rotating the axle at the same time pushing and pulling and "springing" on the pry bar. After about three rotations I felt the C-clip fall in place and it popped right out. Installing it, I put new synthetic grease all around the notch and C-clip on the new one to hold it in place, line it up push it in and pop it in place. A little tug to see if it snapped in... try to support the outer axle end or at least not let it tilt all over the place. keep the axle nut on till youre done so you dont hurt the splines and threads if you accidentally bump it
so a little update, i got the axle out. i guess i just had to get away from it for a while cause when i went at it today it was out within 5 minutes...went to replace the output shaft seal and the one i got from work is wrong(same problem as reklips).
to get the axle out i just combined everything that you guys have been saying, turning it, wiggling it, and using the second pry bar and she came out fairly easily. thanks for all the help guys.
Glad you got it man, I also had troubles just a couple months ago. More info in here--->http://cb7tuner.com/vbb/showthread.php?t=139373
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
