tailight gasket
    tailight gasket
    i hear people talking their trunk leaks all the time and every thread says replace tailight gasket....and now my car is leaking from the outer tailights and it also blew up my amp not happy so my question is what and where is the tailight gasket any one got a pic of this and how to replace it....
    here are the pics on where it is leaking where the black piece meets the car
    MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
    Originally posted by quaidum
    you being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
    good job, just what the world needs more inconsiderate drivers
    After you remove the taillight there is a gasket behind that sits flush where it mounts to the car.
    You may not be able to see it from those pics unless yours was taken off and never replaced.
      is it a foam looking piece.... also is it susposed to have that gap in it...
        damn man while youre at it clean up your lights and run a bead of clear silicone where the edge of the lens meets the housing, i bet your lights look like little aquariums after it rains
          http://www.cb7tuner.com/vbb/showthre...source=message
          Good luck!!
          Whatever the mind of man can conceive and believe, it can achieve. –Napoleon Hill
          Members ride Thread
          Instagram: IbSprintin
            haha it does i drilled two very small holes in the bottom of the taillights so it drains out
              Originally posted by wildcatloe View Post
              yea i think I'm going to buy oem its like 40 bucks for the outer ones....
                You definitely don't want to drill holes in the bottoms of your lights, for next time...
                That's how you get dead bugs in your tails.
                BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
                BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
                Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
                CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
                  Check www.hondaautomotiveparts.com, the 90-91 outer seal can be used for 92-93, and they are only a few bucks (last time I bought some). That seam sealer abouve the taillight needs to be replaced as well, water could be getting in that waw.
                    are you talking about the black piece isnt that attached to the tailight or is seperate....
                      i dont think a bug could crawl in there its that small...
                        I heard somewhere that you can run your tail-light gaskets through the washing machine on a gentle cycle with some clothes, cleans them right up. I can’t speak from personal experience but it’s worth a shot considering how easy the gasket is to replace.
                        MRT's:
                        2001 Acura CL
                        1991 Honda Accord SE
                        Originally posted by Bad_dude
                        If you turn it all the way counter clockwise, you activate the after burner full throttle. Lol. Then when you press it, boom, fast as the T-Mobile data plan chic.
