I have some no name after market rear upper adjustable control arms. My bushings are shot .I don't have the money to replace them since aftermarket no names are about 60$ plus and the OEM ones are even more expensive .So I started doing my low budget research and ran across this http://item.mobileweb.ebay.com/viewi...id=72175272437 has anyone ever done this before or this is something that shouldn't be done. Can I fix my R.U.C.A by replacing this since the balljoints are super nice or should I hit the junk yard and try to swap the balljoint if its possible?thank you
rear upper control arms
Get Prothane. They make bushings for the Ruca. (lol @ ruca)MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by GeoffM View PostGet Prothane. They make bushings for the Ruca. (lol @ ruca)
Then you can replace all of your bushings.-Ian
'92 EX Coupe (Member's Ride Thread)
My Blog - Mostly snark about professional motorsports, but I occasionally make it to local and regional events. It's not much now, but I'm working on it.
Originally posted by LastToBrake View PostIf your budget allows, and you have some patience, I've seen brand new Prothane kits come up on Amazon for $100.
Then you can replace all of your bushings.MRT
