Im buying ngk v power spark plugs for my f22a1 ,, the spark plugs come with a 0.44 " gap ,, on the forum i read that they should be 0.41" ,, should i close the gap to 0.41" or leave them at 0.44" gap ,, any help would be apriciated
V power ngk spark plugs question
Pregapped plugs aren't always correct. It's ALWAYS good to double check, as you did.
Make sure your sources are correct. I'm actually finding mixed answers on this site alone... ranging from .039 to .044 (many incorrectly shown as you have, as .39 or .44)
If it were me, I'd put them in as-is, and adjust them if the engine doesn't seem to run properly. That, or seek a better source of information, since it seems rather questionable on here...
These don't come pre gapped. I put them in a cd5 last week and had to gap them, and I bought them for my 2.0 and I have 2 gap them.**Blk Housed Slut Crew Member #1**
Let's be a little realistic here. Its a lil hard to get it exactly at .042 using that round spark gapper. For me I actually put it at .045 if it goes further I do close it.
.045 seems easier to gap than being so accurat at .042 or.044**Blk Housed Slut Crew Member #1**
Just get the G power. $.60 more and you don't have to (can't) gap them. Problem solved.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by F20A CB7 View PostThese don't come pre gapped. I put them in a cd5 last week and had to gap them, and I bought them for my 2.0 and I have 2 gap them.
NGK's come pregapped, and the correct gap is 1.1mm
Hence the part number - ZFR5F-11
11 = 1.1mm
Convert to metric already . . .
My 5.7 LS1 Holden Ute
Originally posted by Dr. Shuffles View Post0.44" is about the thickness of my little finger. I'm pretty sure that's not the right value.
There must be one "0" before the first "4".
My Haynes manual says .039"to .043".
Decal under the hood of my car says 1.0 to 1.1 mm.
1.1 mm is equal to .04331".
1.0 mm is equal to .03937".
Anything below minimum, there may not be enough spark to promote good burn.
Anything above maximum, there may be over taxing the ignition system.Last edited by oyajicool; 03-13-2012, 08:28 AM.A&P-IA
Originally posted by 10thAnnivCB7 View PostIm buying ngk v power spark plugs for my f22a1 ,, the spark plugs come with a 0.44 " gap ,, on the forum i read that they should be 0.41" ,, should i close the gap to 0.41" or leave them at 0.44" gap ,, any help would be apriciatedA&P-IA
