Hi I was looking on this site about running these cars on water like you can see on youtube. Has anyone done it? How would you do it to help fuel economy?
Running Off Of Hydrogen
^ deeve how can you say that?
Those hho things actually work. I had some professor at school go through the entire process (chemically) and said that in theory you could run your car off a number two pencil a ballast and tap water.
Some ones mod list
I would be dope to do even if you lost HP proabably the coolest mod. lol
"mod list"
bisi header
hi comp pistons
HHO charger lol
The only way/method that generating hydrogen would even be feasable, would be to use the sun or wind to generate the electricity to convert the water to hydrogen.
The best way to use the hydrogen to power the car, is not how you would expect. Instead of burning the hydrogen, like gasoline in our engines, the car would be powered by electric motors, that get their energy from the "hydrogen fuel cell".
The easiest way to explain it is, to think of how a regular lead acid battery generates electricity, the "hydrogen fuel cell" works the same way, but instead of acid, its hydrogen, and a catalyst, mixed with oxygen, generates electricity with a byproduct of water. At least thats my crude understanding of the subject.
well i heard soon it's going to alternating fuel in the future...the only promblem it's more dangerous than gasoline...cause you need hydrogen to be compress...it can actual act as a c4 or a bomb than just gasoline burning up in getting indulge in flamesVS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
Originally posted by curtie94 View PostHow about running the car off of the wind produced from driving, is that possible?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by curtie94 View PostHow about running the car off of the wind produced from driving, is that possible?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
