Steering problems
    Steering problems
    I have a 92 accord lx 5 speed stock everything since i brought the car i notice when i press the gas the car pulls to the left and Also pulls to the right does anyone have idea what it could be?
    Have you messed with the ball joints or tie rods without getting an alignment?
      U have not change nothing just did a tune up spark plug wires spark plugs cap and rotor oil change but i Believe my driverside tie Rod is leaking
        Mine are both shot and it pulls to the right (Also my lbjs are leaking too). It is going into the shop because both parts are oem, maybe even original, and i have never done a tierod/lbj replacement before and would rather have a shop do it. Just in case those bolts are tough to get off
        I would rather do it myself if i knew exactly what i was doing and didn't run into problems. (getting rusted bolts off)
          Im going to change change them i just was not sure and my car Been sitting for acouple of days because of the problem thanks for the information
            Try some basic suspension checks
            MRT
            sneaky motherfucker
